주요 콘텐츠로 건너뛰기
A1708 / EMC 2978 — 2016년 10월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다. Function Keys 버전은 Intel Core i5 및 Thunderbolt 3 포트 2 개를 포함합니다.
216 질문 전체 보기
Display MacBook Pro 13" (A1708) anno 2016
Hi, I have a 2016 13" MacBook Pro Fn system with a display problem it turns off when lifting the screen beyond a certain angle.
Unfortunately I'm not covered by the Apple recall because the time is up. I'm ask if the problem is caused by the LCD-base connection cables or something else?
Joseph
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
[code]
This answer leads me to total despair; I was hoping for the possibility of replacing some cables to solve the problem ... sob!
[/code]
댓글 달기
답변 2개
선택된 답변
To add to @spaeder answer here's a more detailed explanation, in your case you have the most extreme case:
And a vid which also goes over it as well The Design Flaw Behind MacBook Pro’s “Stage light” Effect!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
댓글 달기
가장 유용한 답변
It is caused by the cable that connects the LCD with its small board. Its not the small cable that connects the Logicboard (Mainboard) with the small Display Board.
Here is a pic of the Display with the Board and the Cables that break.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
thank you for the reply; therefore the two cables 'on the sides' of the attached figure have to be replaced; not the small flat in the center. Right?
댓글 달기
귀하의 답변을 추가하세요
giuseppe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 115
