주요 콘텐츠로 건너뛰기
2022년 2월 25일에 출시된 Valve에서 만든 휴대용 게임기, LCD 디스플레이가 장착된 Steam Deck의 수리, 분해 및 문제해결 정보입니다. 모델 번호 1010으로 식별됩니다.
Will opening my steam deck void my warranty?
If I open my steam deck and successfully repair something, will my warranty be voided? If I am unsuccessful will it be voided? Will the simple act of opening it up void my warranty? I want to know before I go repair something in it or just send in my second rma.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I opened my Steam Deck and changed the thermal paste. 2 days later my Deck stopped working. I contacted Steam support and they are sending me a new one and yes I told them I opened it.
댓글 달기
답변 5개
가장 유용한 답변
From Overkill.wtf
"The short answer is: no. The long answer? It's a little complicated.
Thankfully, Valve designed the Steam Deck to make it easy for owners to open it up and replace things on their own. In a welcome move, Valve even collaborated with the excellent 'how to' website iFixit to offer replacement parts and detailed repair guides — such as this complete teardown. iFixit have rated many products over the years for their repairability and give the Steam Deck a good "seven out of ten" rating.
However, the Steam Deck remains an electronic device with a Lithium-battery, and Valve stated clearly in their teardown guide that you should not open it up if you are unsure what to do. This is why they only recently announced their own repair centres."
이 답변이 도움이 되었나요?
점수 6
댓글 달기
Hi @ninjasquid,
Unfortunately, most manufacturers do void the warranty if the device is opened for repair outside their "control". Most countries has certain laws about what does in fact void a warranty, but until the Right to Repair comes through, we're all a bit stuck in limbo.
Some devices have stickers saying warranty void if removed or damaged, but those are far from as normal as they used to be. I always assume that (I live in Norway and we have pretty decent laws protecting the consumer) I void the warranty if I open it. Warranty is normally 2 years over here, but some things have a 5 year warranty.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
You get 5 years in Norway on electronics goods, youre covered under consumer law, and being a part of the EEA that means EU law can apply. https://lovdata.no/dokument/NL/lov/2002-...
댓글 달기
Hi
I had a look for a answer and some people say it will and some say it won’t
I’m quite confused my self I’m how there’s 2 different answers for such a simple question
But from what I know about repairing things,almost all the time the manufacture will void your warranty the moment you open it,if you are having a issue and it’s still under warranty I would get in touch with valve as they should be able to help you out but if they don’t ,we’ll there’s no point in a warranty then so I would go in and fix to your heart’s desire:-)
Hopefully this answers your question
이 답변이 도움이 되었나요?
점수 1
댓글 달기
On my experience(5 times sent to valve for warranty replacements), if you place your ssd or something else you can lose it because Valve can replace the entire Deck in future(if your motherboard fail or cpu, thats why you should keep the original parts to place it back.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
No.
Opening your Steam Deck will not void the warranty, and your warranty is reasonably clear on what does void it.
In principle if the cause of fault with your steam deck can be proven to not be yours and a fault of manufacture or from purchase, then it is on Valve to fulfil the warranty to repair or replace, or in some countries ultimately refund, your Steam Deck.
The comments about removing labels and voiding warranties hasn't been legal for a long time and precedents were set in many country's laws, especially EU, about that.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Squid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 84
전체 시간: 12,321
