주요 콘텐츠로 건너뛰기
2018년 애플 11월 스페셜이벤트에서 출시된 태블릿컴퓨터 고유번호 A1876, A2014 및 A1895.
upper Volume Button Stuck
In the process of replacing a screen and testing it the volume up button is now stuck. i have removed 2 screws which held a cover in place. Is the pcb that the buttons are attached to glued to the chassis? Anyone know?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
From looking at this
https://www.etechparts.com/power-and-vol...
it looks like they have some kind of adhesive on the ribbons
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
There were three screws which i have reoved but if they are glued in place thats just overkill. Problem is i cant get the ipad to power off because of the stuck volume button. I dont know if using a heat gun to loosen the cable will damage the power flex cable.
Thanks for your replay.
as long as you dont bake the ribbon id think youd be ok. just do quick passes on it while gently tugging on it.
thanks, thats what i did and have now been able to fix the sticky volume key issue
@Ask ArgyllTechfix alcohol is almosst always a cure all lol. try taking some and soaking hte button in it while its disconnected and just cylcing the !&&* out of the button and rinse it out with more alcohol. if that doesnt make it click again then the little membrane in the switch might actually be done for and need to be replaced
댓글 달기
답변을 추가하세요
Ask ArgyllTechfix 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 261
