주요 콘텐츠로 건너뛰기
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.
48 질문 전체 보기
Rear back camera lens/glass cracked, any issues using 3rd party lenses
I'd like to avoid taking the entire back panel off and it seems the old camera glass can be pryed off and the new one installed. Wondering if anyone has done this/ how the 3rd party glass compares to Samsung OEM back camera lens glass?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Fed,
Personally, I've replaced lenses on my Pixel 2 and a couple of iPhones and never had a problem with aftermarket glass.
There is something to be said for removing the back cover to do the replacement. For me, the main advantage is that you can do a better job of cleaning out any broken glass particles from the camera lens(es) with the cover off, plus you can push the old lens out from the inside and avoid scratching your housing while prying out the broken glass.
There's a decent video demonstrating the whole process over at iphonewired.com: Samsung Galaxy S21 Ultra Camera Glass Restoration - iPhone Wired, but all in all it's a fairly easy process whether you decide to remove the back or not. If the glass just has like a single crack I'd go for not removing the back, but if it's shattered with glass shards you might want to consider taking it off.
Best of luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Fed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 10
전체 시간: 136
