My Fitbit won’t charge
My Fitbit is dead and it won’t take a charge what can I do
좋은 질문 입니까?
Hey, it depends on whether its not charging or if its not taking a charge.
If it is showing that its charging but after unplugging it you see that its not taking charge its very likely to be a battery issue. To solve that you would need to replace the battery(Available for many of the fitbits) but this requires some technical abilities.
If its not charging at all there is a vast amount of possibilities of what could be wrong but you could attempt to clean out any debris from the charging connector on both the watch as well as the charger.
해당 답변은 도움이 되었습니까?
I Have a Versa 2 and was facing the same issue but Thankfully I have got a solution which was fixed it.
here are few of them that worked for me and a several other on a detailed post.
해당 답변은 도움이 되었습니까?
24 시간 전: 8
7일 전: 54
30일 전: 159
전체 시간: 4,106
댓글 1개
When i purchase my watch after it never charged what should i do
Sheema 의
