주요 콘텐츠로 건너뛰기
9월 24일 출시된 Apple의 2021년 플래그십 스마트폰은 6.1인치 ProMotion OLED 디스플레이, 새로운 트리플 렌즈 후면 카메라 시스템, 5G를 특징으로 합니다. iPhone 12 Pro의 후속 제품입니다.
Booting into recovery mode. Will not restore.
I am trying to fix my iphone 13 pro which spontaneously has stopped working (no physical accident or known damage). This won't turn on at all, including a hard reset. When plugged into a MacBook , the MacBook recognises it is in recovery mode and only gives the option to restore it and erase everything. When this option is selected, the apple logo appears, a blank progress bar appears, and then it fails and an error message on the MacBook is shown saying Unknown Error 9 060E.0000. I have tried this process both in DFU and Recovery mode to no avail.
I have tried multiple different cables, software on the MacBook pro is up to date.
Has anyone experienced this or a similar issue and has any suggestions as to what I can do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Booting into recovery mode and the error you are receiving when trying to restore points to a hardware failure on the logic board (NAND, CPU, and or RAM). Your phone should still be under warranty and I would recommend not opening it up. If for some reason if it is not covered under warranty or you need the data off it you will need to have it looked at by a reputable repairer.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
mahadalimithani 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 239
