주요 콘텐츠로 건너뛰기
2020년 10월에 출시된 새로운 iPad Air. A14 Bionic 프로세서, 10.9인치 화면, 새로운 디자인, 전원 버튼에 내장된 Touch ID 센서를 탑재했습니다.
iPad Air 4 anti-repair measures
Are there any anti-repair boobytraps in this device? Touch-ID of course is probably coupled with logicboard I'm going to assume..
What about the screen for example though? Does swapping the screen with replica variant cause true-tone to disable?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi
This is a really good question HOWEVER…
Unfortunately people haven’t really tried looking for any anti repair traps so they are basically unknown but I can give you some information on what to expect and lookout for:-) (just from my experience from Apple products in general!)
When lifting up the screen be careful of the short screen cables as if you aren’t careful you can rip the connector off the board
Remember to disconnect the battery to prevent any damaged to components
Expect True Tone not to work (might work if the screen data is transferred over with the correct equipment)
Expect a “screen not genuine” message after the new screen is installed
And last but not least expect LOADS of adhesive as that’s what majority holds iPads together
If you have any more questions please ask;-)
Hopefully this helps
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you for all this useful information. I've fixed many devices before and I'm aware of common obstacles. However I need some hard facts specifically about this device. Is the screen locked to the logicboard (for true tone)? Someone who has worked on this device probably knows the answer for sure.
@capacitor
Ok sounds good
Maybe try looking on YouTube for tutorials as they might mention the pairing issue:-)
Hello, I just replaced my logic board into another ipad and I can tell you about the anti-repair tactics that my ipad has. True tone still works even though everything in the ipad is replaced, and there are no “non-genuine” messages. What there is though has something to do with the apple pencil, as after i replaced the logic board the apple pencil is a bit squiggly when you write on it, it didn’t happen on my old ipad. Hope this helps!
댓글 달기
답변을 추가하세요
Sam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 10
전체 시간: 187
