주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kodak PixPro AZ251 is a 16 Megapixel digital camera from Kodak released in 2013. It has a optical zoom of 25x and Optical Image Stabilization (OIS).
Camera won’t turn on even with new batteries
My camera is not really a PIXPRO AZ251 but an AZ401. When I got the camera it had dead batteries, I easily verified this with another battery camera that I have. I bought new batteries but it still wouldn’t turn on, I checked if maybe the batteries were put in incorrectly but they weren’t . I tested the new batteries on the other camera that I had it and they worked. Any help would be greatly appreciated
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Hi,
I had similar issue (Olympus camera) and after all it was power button issue. I just take it to the part and clean the power button contacts and everything was OK.
This is happen because the button is situated on the top and even small leak or sweat can get in.
Are the terminals corroded? If so, I would take a rag (ideally one that you're not too attached to) and some isopropyl alcohol to clean it out.
댓글 달기
답변 1개
try to clean up the power button and check the connecter to the battery, if a pin is bent then try to unbend it and if it's just broken off...
well you need to buy a new connecter at that point
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
But camera is totally new
Get a refund
댓글 달기
답변을 추가하세요
Entrk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 51
전체 시간: 2,511
