주요 콘텐츠로 건너뛰기
Retina MacBook 2015의 업데이트 버전. 모델 A1534, EMC 2991.
140 질문 전체 보기
Is screenless possible with 12" MacBook?
Hi Community,
Will this machine work without a screen?
I recently bought at 12" MacBook (2016) for very cheap off eBay. The idea was to create a screenless "slab top" connected with USBC/Screen Duet to my iPad. Or airplay to the TV. As purchased the unit was working well...
However, I watched a Youtube tutorial and proceed to remove the screen. This was my first time working on a MacBook. I thought everything went smooth but when I put it back together (Screenless) and turned... no power. No start up noise.
Is it possible to pull this off? If so please help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Matus & @hellomacos Sadly SMC services prevents using MacBook, MacBook Air and MacBook Pro's from working properly without a screen.
SMC receives temp for both the display and the camera which without the display assembly will cause SMC to ramp up the fans RPM's (in the case of the Air's and Pro's) as well as lower the CPU's clocking.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
@danj I see
I thought it would work without a screen as I had boards with no screen give me fan-spin when testing without screen and I have seen people using macs without screens connected to external displays like this
https://m.youtube.com/watch?v=3tSMc81w3S...
But perhaps it’s not the case for this model:-)
@hellomacos - Yes, people have gotten the 2016/17 MacBook Pro's running without the display and what they think is working! NOT REALLY
They use a program to control the fan's to bring the RPM's down but they end up cooking their systems. I love BBQ Chicken with Honey! But not MacBook Pro's!
To add insult to injury! As I pointed out SMC lowers the CPU's clocking as it wants to protect the CPU from overheating. So you end up with a slower running system so if you want the ability of the system you bought to render vids or crunch deep spreadsheets forget it! As it will now take twice, three or more likely four times as long!
@danj
That makes way more sense now
hopefully more people will find out about the whole BBQing cpus issue so they stop doing
thanks for the explanation:-)
If apple would make a touch screen Mac I would never had attempted this operation. They are falling behind with the younger generation.
@Matus Modern
I see where you are coming from but that’s what a iPads for ,the macs operating system isn’t really made for a touch screen
It would be cool to see though:-)
댓글 달기
Hi
As far as I know it should work
Iv had macs of all sorts boot up without screens
Are you sure it’s not sure It’s not on and it’s just struggling to connect to a screen as this model doesn’t have a fan so it’s hard to say either it’s on or not(unless you have the top case connected, try clicking the trackpad and checking for a click and click caps lock to see if it turns green)
What I would recommend is plugging the screen back in to see if it will work and checking how easily it will connect to a external display
Hopefully this helps
If it doesn’t leave me a comment
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No green light working on the caps lock. I have ordered a USBC to HDMI so I can check that later this week. I read that there is a yellow button on the logic board that can reset the battery. Is this correct? Should I try opening it back up and pressing that button?
댓글 달기
귀하의 답변을 추가하세요
Matus Modern 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 739
