주요 콘텐츠로 건너뛰기
A heat gun is a device used to emit a stream of hot air, usually at temperatures between 100 °C and 550 °C (200-1000 °F), with some hotter models running around 760 °C (1400 °F), which can be held by hand.
Is it okay to use it at 220V?
I bought this item
This item has a 120V specification but the place where I live supports 220V
Is it okay to use 220V?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
No. Attempting to use a 120v device on 220vac will simply burn it out almost immediately. There may be an adapter for this. The adapter or converter should drop 220v down to 120v to allow using your device. Be aware whether adapter or converter, it should be rated to handle the power of your device and not lower power otherwise it may burn out from over loading it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
박종수 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 218
