주요 콘텐츠로 건너뛰기
Dryer not working after replacing parts
I have a Maytag performa electric dryer the heat was coming out just cold air. I replaced heating element, thermostat thermal fuse, and still no heat… not sure of what else to do. I am a woman here trying to fix this. Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Hi Kelly,
What's the model number of your dryer? That way we can get you the exact information you need to diagnose and fix your dryer.
댓글 달기
답변 1개
가장 유용한 답변
Check your fuse box. It's quite common for a dryer to have two circuit breakers, one for each 120V leg, making a total of 240V going to the dryer. If one of those breakers has tripped but not the other, then your dryer can be getting 120V, which is enough to power the electronics and the motor, but not enough to run the heat.
If you have a voltmeter, measure the power at the plug to verify you're getting somewhere between 220 and 240 volts to the dryer.
Once we know your model number we can give you more information on things like whether there are multiple thermal fuses that you might need to check, etc.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Kelly M jones 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 88
