주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
208 질문 전체 보기
Mac Mini A1347 Status Light Indicator
Hello All,
I have an interesting problem.
I bought a Mac Mini A1347 from Facebook Marketplace from an IT seller. He upgraded the RAM to 16GB along with a 1TB SSD, but in the midst of that, he said he must have bumped something because the front status light indicator does not function. The computer still works without issues, start up, and setup were like out of the box.
Is there a repair option for the status indicator light?
Thank you in advance,
TG
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The White LED on the front panel is part of the power supply assembly Mac mini A1347 (Mid 2011-Late 2014) Power Supply It could be burnt out. Here's the guide to replace it Mac mini Late 2012 Power Supply Replacement
The other possibility is the power supply to logic board connection got damaged in the process.
Mac mini A1347 (Mid 2011-Late 2014) Power Supply 이미지
상품
$79.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
THANK YOU SO MUCH FOR YOUR ANSWER! It means a lot and make sense.
Would replacing the power supply fix if the indicator is burnt out or the connection got damaged?
Thats the hope! Unless the logic board connect its self is damaged so when you replace the PS check it.
Thank you so much for your input, Dan. I will be ordering the power supply and then replacing it. You rock!
댓글 달기
귀하의 답변을 추가하세요
Tin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 240
