Guides and repair information for Philips CT scanners. Philips CT scanners can generally be identified by the name “Philips” printed in black capital letters on the top front of the machine.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Large equipment usually have cabling everywhere. Movable arms will have internal/external cabling tied in place with sufficient cable slack to allow flexibility. Under normal circumstances, a qualified technician from Philips will make visits to restore equipment or make repairs as necessary. While not encouraged for anyone unfamiliar with complex equipment, some things are easy to check; blown fuses, loose connections, damage. At the least, power should be completely removed to prevent electrical shock before opening access panels. If power wiring is permanently connected then pulling the main breaker handle to shut off power and physically locking the lever with a padlock can prevent any one inadvertently repowering this equipment while access panels are removed and someone (out of view) is working inside.
F Dryer 의
