Replace Printer mother board
My Printer is dead. Only the power light is on. I believe the motherboard is dead. How can I make a replacement?
좋은 질문입니까?
좋은 질문입니까?
Is printer making any sound while initializing -when just turned on? Like spinning shafts doing some calibrations or such? Computer when printer is connected, - is it displaying any error code or message popping up on screen of PC? If you connect printer via USB - do you hear any notification from your PC - that it's detecting USB device?
If you think you need new board here is a link to Aliexpress with board, it could take a while to get it here though
https://www.aliexpress.com/item/40011780...
Also I would suggest to remove cover from side where main board is - and check what part number is on sticker of board and google where you can purchase that board other than in China.
이 답변이 도움이 되었나요?
думаю, что более вероятно вышел из строй блок питания принтера. блок питания должен выдавать +5 вольт и +24 вольт. в вашем случае может быть только одно напряжение +5 вольт, оно и дает питание на индикатор.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 471
