주요 콘텐츠로 건너뛰기
Apple이 2019년 3월에 출시한 새로운 iPad Air 태블릿, A12 Bionic 프로세서와 10.5" 스크린을 자랑합니다.
35 질문 전체 보기
Why can I sometimes not type correctly or touch the bottom of screen?
This started happening after I cracked the top left corner of the iPad.
Sometimes, but not always, when I type, it doesn’t work right.
Example:
I tried typing “example text”
I got “eaple. tet”
Whenever this happens, I can also not interact with the bottom inch and a half of the screen.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It sounds quite likely that you've damaged some of the circuitry that controls the touch screen function, i.e., the digitizer.
Unfortunately, on your model of iPad it's not possible for the average person to replace just the digitizer glass, as it is fused to the LCD display, so the only option is to replace the entire LCD / digitizer assembly.
There are several sources you can buy a replacement screen from, including right here on iFixit.
iPad Air 3 Screen - iFixit Store
If you're feeling adventurous, there's a DIY guide that will step you through the entire process of replacing the screen yourself.
iPad Air 3 Screen Replacement - iFixit Repair Guide
Good luck, and let us know how it goes!
iPad Air 3 Screen 이미지
상품
iPad Air 3 Screen
$199.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Ldangerous1 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 25
