이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 7개:
Have you reassembled it correctly? It might spin freely when you spin it with your finger but once it’s screwed together it can be squeezed and tighten up. Also did you clean the base of the fan? The motor and bearing area as dust and dirt can accumulate there too. Some people think just cleaning the fan blades is enough but it’s not.
@strongbow I thought I had gotten to everything. But, it was working fine after I cleaned it. It wasn't until I dropped that it started sounding super loud
[deleted] 의
José Garcia 의
So you dropped it after cleaning it? Open it up again as something has either moved or bent out of shape.
[deleted] 의
I was just about to do that. Hopefully everything is ok after 🤙🏽
José Garcia 의
Ok guys I got it!
José Garcia 의
댓글 2개 더보기
