주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
I want to check my water indicators.
Hi all.
My iPhone 4s got wet the other day (not fully soaked or immersed but wet). It stopped working properly for a while but some time in a "Thirsty Bag" seems to have sorted it.
I would like to check the water ingress indicators; in case it plays up again I dont want to waste my time if the indicators have changed.
1. Where are they?
2. What do they look like a) when normal/ b) when water detected?
3. Photos would be appreciated.
Thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Well I sent it to Apple and they replaced it so the question is now moot. Next time it's an Aquapac for me when out hiking.
댓글 달기
답변 2개
선택된 답변
There should be 3 in the phone. One in the headphone jack, one in the dock and some in the inside of the phone. If they're activated, they will be pink if they're lightly soakked and red if it was fully submerged.
To check the internal sensors, you're probably going to need a pentalobe screwdriver. This is the driver you need.
P2 Pentalobe Screwdriver iPhone 이미지
상품
$5.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
my iphone still works but i dont have sound. i looked down the headphone jack andd it is pinkish white/red. how can i fix this
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You cant without replacing parts
the 'pinkish white/red' is the water damage indicator.
even if you do, the board itself may also be damaged.
댓글 달기
귀하의 답변을 추가하세요
Ernie K 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 21,272
