주요 콘텐츠로 건너뛰기
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
239 질문 전체 보기
iPhone SE 2020, restarting every 180s because of tg0b, board defect?
Hello Guys, i need help. I have an iPhone SE 2020, replaced screen (by me) which is now kernel panicking and restarting every 180s (has nothing to do with the kernel panicking, screen replacement was done now a year ago). It has no obvious pry damage, the mosfet by the battery connector is still in place and not moveable. With both the OEM Battery and a new 3rd party one the kernel panic keeps happening as well as the 0% battery charge thing. In the logs "missing tg0b" is stated. When starting without the dock and front camera flex attached the logs state "missing tg0b and mic1", so i suppose its a board issue? Any tips?
Update (07/26/2022)
The battery connector
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
One of the data pins looks to be pushed into the plastic but I cannot be certain. The measurements you took are okay.
댓글 달기
답변 3개
가장 유용한 답변
This does sound like a battery data problem. The first thing to check would be the battery connector as they are known to be problematic on this model. Check the pins have not been pushed into the plastic, if they have you will need to pry them out. The next step would be measuring the pins with a multimeter in diode mode. Also there are two fetts near the battery connector not just one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i measured the pins and got the following readings: GND for GND and 418 for the 2 big pads on the other side as well as 689 for the data pins. Ill post in another comment a picture of the connector
댓글 달기
Hi Benjemiah,
The error code refers to Temperature monitoring chip on the motherboard stopped working due to no feedback from the temperature sensor it has gone to fail safe mode (restart for every 3 mins)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
So it is not a Battery SWI Problem? How can it be fixed?
댓글 달기
See this youtube link: https://www.youtube.com/watch?v=GSH2Y-Sp...
This will show in detail the circuit board issue
This is reference to the Panic restart every three minutes with reference to Mic1 not being found
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
benjemiah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 20
전체 시간: 362
