The all-new GMT900 generation of the Silverado/Sierra arrived in the last quarter of 2006 as a 2007 model. It features a redesigned exterior, interior, frame, and suspension as well as a power increases on certain engines.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
If these backup lights aren't damaged, cracked and allowing water in to collect, they may have aged until the seal dried up and opened to allow water/moisture in. Each backup assembly would need to be removed to examine them after cleaning off dirt built up. One method is baking them in the oven (search youtube videos for how-to and temperature) to split open an assembly. Cleaning then using sealer like silicone caulking or other recommended sealer should prevent future moisture collection. A well placed small hole on top and bottom may allow moisture to vent.
F Dryer 의
