주요 콘텐츠로 건너뛰기
오랫동안 기다려온 인기 MacBook Air의 참신한 업데이트는 Intel Core i5 프로세서, Retina 화면 업데이트, 그리고 기타 수 많은 변경 및 업데이트를 포함합니다. 2018년 11월 7일에 출시되었습니다.
150 질문 전체 보기
The battery in not charging
Hello,
My, 2018 MacBook Air 2018 does not charge and I want to know the reason.
The only way is, if the adapter does not work, I ask? I have a HUB with 4 USB inputs and a MINI USB output (or USB 2), to connect to the input of the computer.
Can I connect this Hub to another adapter (Apple), and be able to charge the battery?
To know if the problem is the original adapter, the cable or the battery that is failing?
I hope you understand what I'm asking and I appreciate an answer to my question.
THANK YOU
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Your system uses USB-C for the power input. If you can borrow someones USB-C charger (any) you should be able to charge your systems battery. That is assuming the larger is the issue!
Personally I find having a USB-C power meter is the more useful way to diagnose issues like you have here. Plugging it into your systems USB-C port and then plugging in the power adapter and cable you should see voltage present and the current will tell you if the system is able to accept the power offered. ICQUANZX USB-C Power Meter
Think it like water, does the tap have water to it and if the tap is open or closed.
This will allow you to tell which side of the circuit the issue is located externally or internally! Let us know what you discover!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
narso chola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 81
