주요 콘텐츠로 건너뛰기
10월 13일에 발표된 iPhone 12 mini는 Apple iPhone 12의 소형 버전입니다. iPhone 12 mini 특징은 5.4인치 OLED 디스플레이, A14 Bionic 프로세서, 그리고 듀얼 후면 카메라 입니다.
57 질문 전체 보기
TrueDepth camera not working after water damage, any hope?
So, while I was at the Dutch quadrennial hackercamp MCH2022, I unfortunately dropped my phone in the water while swimming. Usually not such as big deal, well, except that I had gotten my battery replaced a month prior. I had it done at Apple officially, hoping that it would still be water proof (I knew very well that it might not have been, but they didn't tell me and I kind of expected the official repair to still retain waterproofness, but ah well). Well in any case, it did get water damaged.
Now that I'm home, I'm attempting to see if I can salvage the phone (replacement already bought for the time being and it was insured anyway), and I got it working nearly perfectly again (just need to clean the volume up button), just not Face ID (the TrueDepth camera).
I'm not scared of a challange, and my insurance already covered the damage anyway. My contract is ending late August, and September is new iPhone month as well. So I'm not really too concerned if I break it further, would be a shame obviously but not the end of the world. So I figured, is there any hope I can get FaceID to work again? It's still the original sensor anyway.
Fun fact: during the water damage, the battery got reported as non-original, but now that it's opened and I've cleaned the connectors etc. it's reporting as an original part again.
Edit: too few details, here's some more:
  • Settings -> Info -> Face ID "Problem" message
  • Front camera is working fine
  • Message "Face ID is not available" popped up
  • Then I made the stupid decision to reset the Face ID settings, leaving them grayed out. Performing a recovery restore now.
Edit 2: more testing, the dot projector isn't working.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Okay, first things first. You say the TrueDepth camera isn't working and indicating that you have no Face ID. Lets elaborate on that. Exactly what kind of problem are you having? Do you have an image from the front camera? Does it say Face ID is not available? Are you getting the 'Move iPhone a Little Lower/Higher' message?
@dadibrokeit Sorry bout that, will include details in the main post.
@dadibrokeit Okay, after a quick restore and the ol' pointing my phone at my other phone, it seems like the IR is not working (that's the Flood Illuminator, isn't it?). edit; Some further testing, Portrtait mode doesn't seem to work on the front camera. The IR LED seems to light up fine. I probably tested it wrong earlier. Edit 2: aha, the dot projector isn't working.
I'm a little confused. If the dot projector isn't showing signs of life, could this be related to a non-functioning flood illuminator?
댓글 달기
답변 1개
가장 유용한 답변
To help your diagnosis, check out the video on the following post (there are steps available, but they're rather light on actual information).
Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher' - iFixit Repair Guide
Unfortunately, the dot projector seems to be one of those parts that are particularly susceptible to water damage and ultimately non-repairable. Well, at least not for us average joes. There is one guy, Phyrne, that seems to be associated with the rework company REWA that has fixed one, but man, it's way beyond what most of us can do. Check it out.
iPhone XS Max Face ID Not Working Fixed - Dot Projector Repair - iFixit Repair Guide
From what I've seen, the only part of the Face ID system that can actually be replaced is the front camera itself, which requires disassembling the front camera assembly. That, while difficult, seems to be doable by us mere mortals. There's an iPhone 11 Pro guide to doing that, but once the front camera assembly is out of the phone, the process should be the same for your 12 mini.
iPhone 11 Pro Front Camera Replacement Without Losing Face ID - iFixit Repair Guide
The only other thing I've seen that offers any hope in situations like this is that malfunctioning rear cameras can apparently affect Face ID, but since they're not tied to the camera they can be replaced without issue. It's unclear exactly what the connection is between the rear cameras and Face ID is, though.
iPhone X 이미지
안내서
난이도:
운영
iPhone XS Max 이미지
안내서
난이도:
어려움
iPhone 11 Pro Front Camera Only 이미지
안내서
난이도:
어려움
40 minutes
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
The first link mentions the flashing of the dot projector in portrait mode, but wouldn't that be the flood illuminator? Can you actually check whether the dot projector does anything (by pointing another camera at it)?
https://www.youtube.com/watch?v=ny0_sus2... here is how it works and the diff bw them
댓글 달기
귀하의 답변을 추가하세요
computer1up 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 29
7일 전: 303
30일 전: 1,197
전체 시간: 16,891
