이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 3개:
I don't really understand your question. Can you please add some more details about your problem, such as if something like a drop has happened and if there is no response at all when trying to turn it on or putting it in a charger?
Erik Eriksson 의
iPhones aren't cars, they don't run on engines.
guardian10 의
Connect it to a charger then press and let go
Volume up
Volume down
Then press and hold power for about 30 seconds or until the apple logo appears.
See if that helps.
[deleted] 의
