주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 Dying at 4% after battery replacement!
I have an iPhone 6 and it randomly started to bootloop.I knew it was a battery issue, So I went into battery health and it was just loading.So I went to the same place I got my phone battery replace and they replaced it again.Everything was going great until my iPhone was at 4% and it randomly died.I plugged it in but instead of showing the low battery logo it showed the apple logo and it was at 4% instead of 1%.What should I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Have You calibrated the battery?
댓글 달기
답변 1개
가장 유용한 답변
Try calibrating the battery
Run it down until it shuts off,
Then charge it up to 100% uninterrupted then keep it plugged in for 2 more hours,
Run it down till it shuts down,
And finally, charge it uninterrupted to 100%
해당 답변은 도움이 되었습니까?
점수 1
댓글 7개:
I was going to mention calibrating the battery as above but I’d run it down to 10% and then charge again rather than letting it die. But do what @beanman56 says.
@strongbow - It’s very necessary for the calibration to be done completely as it’s said,
Otherwise it’s probably gonna be the same
To be honest, they don't need calibrated at all. Calibration was for the old nickel based batteries. The newer lithium based batteries don't need calibrated. They are basically plug and play. I wouldn't worry about dying at 4%, it should work itself out over a few charges.
@strongbow - Then explain why ifixit says to calibrate the battery
Ask them? I’m not trying to explain someone else’s mistakes.
https://discussions.apple.com/thread/789...
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
Keshawn Vasugan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 81
