주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Battery is not detected after install.
My iPhone X wasn't charging, so I assumed the battery was dead and replaced it. After installing the battery, I realised that it did not fix the issue. The phone did bot up as normal after some time on the charger, but it continuously showed the battery to be empty.
I then uninstalled the battery altogether and tried booting up the iPhone on the charger alone. It again booted up after a short period of time and showed an empty battery.
The phone doesn´t seem to care, whether a battery is installed or not. It just doesn't detect it. Does anyone know, what the cause of this could be? It surely has to have something to do with the logic board. I wouldn't shy away from attempting a repair on that, I do have some experience dealing with small PCBs from my other hobby. It´s just that I have nothing to go off of, really. I couldn't find actual information on how to further diagnose this issue.
I would really appreciate a little guidance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
there are plenty of videos on youtube showing no charging issue repair. if you want to attempt repair yourself then watch the videos that have microsoldering involved and you will understand it better than someone trying to explain it
댓글 달기
답변 1개
선택된 답변
Sounds like a charging ic issue. Chip SN2501. Replacing should sort it. Good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
psander0504 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 57
