주요 콘텐츠로 건너뛰기
동일한 모델 번호(A1932)와 EMC 번호(3184)를 사용하는 2018년 후반 MacBook Air의 소규모 개선에 대한 수리 정보 및 안내서입니다. 이 모델은 트루 톤 디스플레이와 약간 수정된 배터리가 특징입니다.
20 질문 전체 보기
Touch ID and Keyboard backlight don’t work
Hey guys,
Picked up a MacBook Air 2019 for a bargain recently. The machine has 3 issues:
1. Trackpad was glitching/not responding at times - this seems to be solved by disassembling, removing the trackpad, cleaning and reseating contacts.
  1. Keyboard backlight does not work no matter what I’ve tried, cleaning contacts, resetting NVRAM etc nothing. Backlight function keys do not respond (no pop up on screen), trying to set brightness via control center immediately slides the slider back to off (left). The keyboard is fully functional though
  2. Apart from the backlight, Touch ID does not work, not in safe mode, not after reset. When I try to add first fingerprint, right away it tells me “Failed: unable to complete Touch ID enrollment. Please go back and try again.” Power button works though
Now after tinkering inside the mac, I can tell that someone else’s greasy hands have definitely been inside. Stripped/missing screws, peeled tape etc. True Tone is also gone meaning either the screen or the board have been replaced.
Touch ID is not a massive issue but I wanted to find out if anyone has had a similar issue with the keyboard backlight and if that can be restored?
Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
This will need some doing! I would locate the schematics and board view drawings for this system (if you can) as you'll need to trace out the power rails. It's likely the rail the backlight uses is having a problem. You might locate the TouchID is also sharing this rail.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hi Dan, thanks for the reply. Knowing that almost everything Apple is proprietary, didn’t think that schematics are public. Do you know any sites where I can find these?
Thanks
@lex1 - Search for the logic board number schematics 820-01521
댓글 달기
답변을 추가하세요
Lex Zahv 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 295
