주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
56 질문 전체 보기
Curved line under screen
There is a curved line under the screen. When I touch the screen it does not feel cracked. It goes away when I turn the computer off. What’s the problem and how do I fix it. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Retired Mac repair person – doesn't mean I know everything, but that I've done a whole lot of repairs and have seen things.
Your display has layers, the glass being only the part closest to you. There's an interesting teardown of the retina display here on iFixit, and if you want to geek out, you are welcome to read it. My point is that things can happen other than cracked glass. If your computer were on my bench, I would:
  1. With the computer off, run a credit card or similar thin plastic all over the screen, edge first, to see if I could locate a hairline crack that was otherwise invisible to the eye. If I did, I would feel a little "click" as I ran across it. I would not press hard, just enough to catch any edge. Then, if that did NOT produce any results, I would...
  2. Boot up the computer, and carefully flip it upside down, holding it by the bottom case (keyboard part), with the screen towards me. Then I would shake the computer a bit, to see if the curved thing moves. Reason: If it's a loose wire that has fallen down, doing this will probably make it move around. If that didn't do anything, I would...
  3. Shut it off again, find a really powerful flashlight or lamp, and – holding the open computer in both hands so I don't drop it – turn the screen this way and that to see if a powerful light will reveal any anomaly in the screen. This sometimes works to reveal issues with one or more of the underlying layers. You might need to get really close with the light, and run it around using different angles. Pro Tip: You can shine a light in through the Apple logo, as well.
Because that line is semi-circular, I will take a wild guess that someone sat on your Mac and – realizing their mistake – jumped up before it showed any obvious dent in the case. This would flex one or more of the inner layers and create a butt-shaped "wrinkle" in the display. However, I would also not be surprised if a small wire had come loose and was hanging down instead. If I were to place a bet, though, it would be on the Butt Damage option. It would mess up the display without necessarily causing a crack in the glass. And it would disappear when the computer is off (but see option #3, above).
In any case, if this is showing in all apps and Finder, you are looking at a physical issue which will likely involve replacing the display. Taking those displays apart is a royal pain in the part of the body I think sat on your computer, and such "repairs" often end badly.
해당 답변은 도움이 되었습니까?
점수 4
2 댓글:
@willardroad has given a detailed, thorough answer that I whole heartedly agree with. Try the steps outlined above and let us know what you find.
The bad part is that, for us "normal" people doing our own repairs, we pretty much have to consider the MacBook displays as unrepairable; as mentioned previously, it is extremely difficult and undoubtedly requires specialized equipment to disassemble a MacBook screen.
The only thing that leaves us is the replacement option, which of course can get expensive. A used display will usually be the cheapest option; eBay is probably your best bet for that. Otherwise it may be possible to get a new replacement part at a semi-reasonable price on something like Amazon, AliExpress or even eBay.
Good luck, and keep us up to date on how it goes!
Writing to agree with Jerry and add a bit more.
Years ago, I ran an Apple Authorized Service Provider where we tried to fix everything that came in the door. We were the only repair facility for many miles, so we got loads of repairs... some of which we should not have even tried. Mac laptop displays fall into that category, but like a buncha dummies we kept trying. Sometimes succeeding, but mostly failing.
The reason: Apple's laptop displays are fabulous... and fragile. When they work, the colors and clarity are magnificent. When they don't, or when something stupid happens like sitting on one, or packing it too tightly in luggage, the displays get hurt and are an absolute nightmare to repair.
Here's a tidbit: To remove the bezel of any older MacBook Air, those wedge-like ones, required the use of a heat gun, oven mitts, and special shims we had to invent because none existed at the time. And frequently failed anyway. Totally not worth it.
I love Apple products, but repairing displays? Not so much.
댓글 달기
귀하의 답변을 추가하세요
Alexander Wnorowski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 83
