주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Maxima는 2009년형 모델로 재설계되었으며 2008년 뉴욕 국제 오토쇼에서 처음 공개되었습니다.
OBD giving 1778 engine light code
My car is accelerating slow after coming to stops. The engine light is giving me a 1778 code and after some research I learned that I needed to replace the stepper motor. After replacing the stepper my issues were still there. I tried replacing the Mass air flow sensor and the problem is still there as well. What else could I try?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Try searching for Nissan Maxima forums. Owners share info freely and may help you. If you have a cvt, this may be a known problem.
의 공유
댓글 달기
답변 1개
After installing the parts you have to reset the error codes. You can wait for few miles to detect the issue has been solved and the error code will gone. It is also possible you have some more parts has fault. Please contact any expert technician locally to examine the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Quincy Williams 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 23
전체 시간: 398
