The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup. For the 2006 model year, several improvements were added to the F-150 lineup.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
Kelly Powell I am confused "will shift manually " "shifter in the steering column won't shift " reads like it shifts but it does not shift. Okay so its an F-150 with a Manual or Automatic Transmission ( I bet it's automatic ;-) What happens when you move your shifter? Do you feel any resistance etc.?
Its an automatic I've had to get underneath the truck to shift it there's no resistance on the shifter the previous owner said the truck needed a shift pin that the old one broke on him twice
oldturkey03 의
Kelly Powell 의
