주요 콘텐츠로 건너뛰기
How can I fix the low volume on iPod Shuffles?
I have 6 of these iPod Shuffles 2nd Generation and they have always worked well. But I got them out of storage today and the volume on all of them is too low to hear anything that's on them. I've tried different speakers but that doesn't make any difference. What has caused this? Is there any way to fix this problem or are they permanently useless now?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi
It might be a bad battery causing the issue but it could be that you are using headphones or speakers that have too high a impedance (ohms)
Basically the more ohms something has the harder it will be to make it sound good and get loud
To check if it’s a impedance issue use the apple headphones that come in the box to see if the issue persists
If you charge the iPods up and see how long they last that should give us a indication of the battery’s health
If you do decide to open them look out if any damage,discolouration or corrosion as it can cause these sorts of issues
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I've now tried a pair of small Sony computer speakers 8 Ohm/0.2W and that didn't work. The Apple headphones worked well and the volume was good. Also tried a small battery-powered plug in speaker and that works well although the volume isn't as high I would like. So I'm not sure what that means as I don't know much about this technology.
@imarthur
If it’s working some of the time but not all of the time have a look inside to see what’s going on better
They might just need new batteries or it could be something else
댓글 달기
답변을 추가하세요
Arthur_Dent 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 231
