My laptop is not turning on
My laptop power light is blink but nut turning on
좋은 질문입니까?
Go through a process of elimination. Remove the ram, remove any graphics card that may be installed, check the bios settings. One or more of the hardware items may be causing the issue.
이 답변이 도움이 되었나요?
Hey, if the power light is "blinking," there's a good chance the video card is damaged. Video cards are extremely sensitive, so be extra careful when working with it. Also, the RAM might be acting up. Check both of these things, and see if that solves the problem.
이 답변이 도움이 되었나요?
It's look like Motherboard problem. Mighbe EC bios failure or IO ic failure.
이 답변이 도움이 되었나요?
Cuando busque de los posibles problemas mire que si parpadea con tiempo superior a dos segundos es daño en la cpu
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 14
지난 30일: 22
전체 시간: 591
댓글 1개
Pranav Prajapati what have you checked? What have you tried to fix this?
oldturkey03 의
