주요 콘텐츠로 건너뛰기
2018년 3월에 출시된 Apple iPad 6의 Wi-Fi 전용 버전입니다. 32GB 및 128GB 스토리지 옵션으로 제공됩니다. 9.7인치 레티나 디스플레이와 64비트 A10 퓨전 칩이 특징입니다.
Replaced digitizer, LCD not working the same
I replaced the digitizer on an iPad 6 (that was working 100% aside from the shattered screen) and now the LCD is not cooperating. Blocks of grey/white/black along the top edge. It lights up; it makes the sounds when plugged in, there was even a brief moment when though half the screen was giving white lines/blocks, I even saw the Apple logo. I’ve tried reseating the connector cable, I’ve placed a card under the battery before disconnecting the LCD, I tried the hard reset…. No luck.
The power button works; the home button works. Everything else works as it should
Can anybody confirm if the LCD really is beyond repair (somehow I damaged it in the extraction?) or if it’s something else. The prongs all look good, nothings shorted… I’m at a loss.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
That's a common symptom of a cracked LCD. Apple uses that black epoxy on the corners where the LCD screws go which makes removing it it a delicate process. The LCD was most likely flexed past its tolerance point and cracked. Replacing it should get the iPad back to normal.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi Robert.
I changed the display LCD and look it.
The IPAD reboots alone each 3 seconds and the display appears like in the video.
Is IPAD 2018 6gen
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Ah. When I have seen this across multiple LCDs on the same device it typically points to the connector for the LCD on the logic board being damaged or components near it knocked loose.
yeah Robert the new LCD is Broken. Now with a new LCD is working
댓글 달기
답변을 추가하세요
Jade t 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 327
