My headphone jack is not working
When I insert my earphone in Jack it does not appear to insert and no music is heared
좋은 질문 입니까?
좋은 질문 입니까?
Take a cotton bud and put some isopropyl alcohol on it. Then insert it whist rotating it into the port. Due it a couple of times to clean it out.
해당 답변은 도움이 되었습니까?
I cannot say for sure without being able to see it but sounds as if there's something either stuck in the jack or the female part has fallen apart inside or gotten bent!
해당 답변은 도움이 되었습니까?
Start by using a flashlight to check inside of the Jack to make sure that there's no debris in there.Then take AQ tip with rubbing alcohol.Clean carefully down inside of the jack. If that doesn't work then you're gonna have to take Your phone apart somehow and take out the logic board and reflow the solder joints of the jack itself. But I stress that you double check your settings to make sure that it is allowing you to utilize a headphone set up With the Jack. Also, make sure your volume dial on the headphones is up and try utilizing a different pair of headphones. If you don't have a different pair of wired headphones, then you can go to a Dollar Tree 5 below or really Any dollar store and pick up a really cheap pair of headphones that can always be returned and try those out. And i hope this helps you. Please let me know if you get it figured out. Have a good day
My jack is not working
해당 답변은 도움이 되었습니까?
What jack isn't working and what kind of device is this jack on, and when did it start happening and what were you doing when the problem started?
Use a flashlight to look into the jack for signs of dirt and debris, carefully use IPA 90% on a Q-Tip and twist it in and out of the jack, check your phone settings and make sure wired headphone connection is allowed and on. Or lastly carefully take your phone apart(look up a teardown video) take out the logic board and reflow the solder joints of the jack. And lastly if all that don't work then back up your entire phone except the settings and then factory reset the phone(this should be done every other month anyway). That's my advice to all out there hope it helps!!!
해당 답변은 도움이 되었습니까?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 40
전체 시간: 495
