주요 콘텐츠로 건너뛰기
Repair information and troubleshooting for the Dell Alienware 15 R2, a gaming computer made by Dell.
plugged a usb in to my laptop and just went dead
I have same problem as above, plugged a usb in to my laptop and just went dead no lights, but when I plug the power cable in the light is a blue circle.
Update (08/30/2022)
Is their a schematic for the 15 r2 — AAP21 LA-CI2P
Rev: 2.
0 ( A01)
2015-10 - 01
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
D M you've checked the Rev 1.0 to see if that at least would get you into the ball park?
Yes there is a schematic, I can search for it , or maybe on sorin-s forum , aniway It seems that my M11X died in similar way , Plug'ed in a "so called SSD kingstone msata" , and it not post anymore. I wen't trough flashing the bios , and it complete's but no success after. The key combo to activate the Phoenix Crisis Recovery on the M11x is simply pressing the "END" key while plugging in the A/C cord . And it beeps confirmation after finishing (read's from USB tumbdrive).
Opened up the M11X , and found a few stuff wrong inside , was missing something at GPU lvl , SMD mounted that and flow-n it , but southbrige heat's up (more than it should) , and Not enough voltage after power-up to GPU (reads 1. someting or 2.v nowhere near enough , so may be a busted vrm also) , I just gave up for now . Was unable to determine the corect procedure to fix it , (it beeps so bios seems fine , but blank screen , fan's loud - that's it).
댓글 달기
답변 2개
Try removing batteries, pressing holding power button to drain power(more time you press the less likely you need to repeat procedure), re test with a good known power adapter. Check old power adapter to see if correct voltage is given, using voltage meter.... if nothing works reseat ram(use 1 module) ,repeat procedure. Or gpu or ram or bios or power problem(these are most likely culprit.)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes there is a schematic, I can search for it , or maybe on sorin-s forum , aniway It seems that my M11X died in similar way , Plug'ed in a "so called SSD, internal slot" , and it not post anymore. I wen't trough flashing the bios , and it complete's but no success after. The key combo to activate the Phoenix Crisis Recovery on the M11x is simply pressing the "END" key while plugging in the A/C cord . And it beeps confirmation after finishing (read's from USB tumbdrive).
Opened up the M11X , and found a few stuff wrong inside , was missing something at GPU lvl , SMD mounted that and reflow-n it , but southbrige heat's up (more than it should) , and Not enough voltage after power-up to GPU (reads 1. someting or 2.v nowhere near enough , so maybe a busted vrm also) , I just gave up for now . Was unable to determine the corect procedure to fix it , (it beeps so bios seems fine , but blank screen , fan's loud - that's it).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
D M 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 415
