주요 콘텐츠로 건너뛰기
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
129 질문 전체 보기
isight, power and volume buttons not working after drop. Logic board?
Greetings!
The other evening I dropped my first gen iPad pro 12.9, which was in a case, and the upper right hand corner hit the floor. Upon picking it up, I discovered the volume buttons no longer worked. I then tried the power button and it was the same. I then started testing other functionality and found the iSight camera no longer works. The front camera still works without issue.
Does this sound like an issue where the cables came loose, or is this probably a situation where the logic board is damaged? Anyone experience something similar? Any assistance is greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Sounds like a component issue to me. In the 12.9” iPad, the logic board runs through the center of the battery, it’s sort of a weird arrangement. But both the button cable (the power button and volume buttons are on the same cable), and the rear camera plug into an extension cable to connect to the actual logic board. You can sort of see from this torn down image what I mean (I tried to find a better picture, but alas…..). It’s definitely possible this popped out or something of that sort in the drop, even though it’s supposed to be held down by a screwed in cowling.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Thanks, Alisha! That is just what I needed. I replaced the screen a few years ago, and I'm almost certain i cut some corners when putting it back together. I probably have said cowling sitting in a box somewhere.
@n7nolan I certainly wouldn’t fault you for it. IPads are a bit of a chore to work on in my opinion. I literally have an iPad 7 on my shelf right now waiting to go back together and I just don’t want to. Hahaha.
댓글 달기
귀하의 답변을 추가하세요
tom jones 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 31
