Why wont my car still start?
I have a 1999 oldsmobile alero I just replaced the ecu box and ignition . The security light finally stopped blinking and the doors chime again and the trunk opens again but it still won't start. When trying to start it it does turn off like it did before switch parts now it seems like there is no gas or battery no juice but there is gas and battery good. Why won't it start still?
좋은 질문 입니까?
댓글 2개
There is gas in the gas line to the injectors. Is it suppose to be under pressure or weak when push on gas rail?
Jennifer 의
Yes, there should be pressure with fuel spraying out when ignition is turned on. Presuming the fuel pump is working with pressure on the fuel rail, this doesn't tell you if injectors are operating. After several starting attempts, spark plugs should be wet with fuel to indicate injectors are operating.
F Dryer 의
