주요 콘텐츠로 건너뛰기
Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
40 질문 전체 보기
Phone Shows Charging But Percentage Not Goes Up.
my phone charging slot have been changed. now it shows fake charging sign. i.e. percentage not goes up but show that it is charging.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Mayank,
It seems the phone is not charging and uses real power pls do the following steps.
  1. Check the charger output Amps(current) if you're using original charger then no need to worry about this one.
  2. Turn off the phone and charge it check if the phone is turning on or not.
  3. If phone turns off during step 2 then phone charging circuit is damaged and needs to be repaired.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mayank 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 39
