주요 콘텐츠로 건너뛰기
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
Mac Pro 3.1 RAID card with SSD on system drive
Hi guys,
I have Mac Pro 3.1 and Apple RAID card and I am wondering if will worth to make SSD RAID 0 for system. I am using Mac for photo and video editing and I am not sure if will be any massive performance ?
Thanks a lot for any ideas.
EDIT: I have this one
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@mayer - Any thoughts? You have more experience on these system.
댓글 달기
답변 2개
선택된 해법
Hi
If you can figure out a way to use the pci slots I could see it having a nice benefit in terms of reading and writing speeds
You could get a card that takes 2 m.2 SSDs and raid them together to make a very very quick drive
You will need to take into consideration how much space your pci bus has left as if you already have one raid SSD so you could be close to maxing the pci bus on it and adding more might not have a big if not any increase
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
I have original Apple RAID card :) so will go with 2xSSD 2,5 in Bay 1 and 2 but I am not sure if it's worth time and effort :)
@roboscrap
It really depends on the speeds you get as if you are already getting something like 1700-2000mbps if you add any more you might max out the PCI bus and won’t see much of a difference if not any at all:-)
My current SSD have 500 read and 450 write :) so if I go with RAID 0 I should have 1000/900 ?
@roboscrap
I can’t say you will get exactly double but I think you could get some Improvement
How much of a improvement,I can’t say for sure but here’s a more in depth video that I think that could help
https://m.youtube.com/watch?v=8VBwuowBnR...
@hellomacos Thanks a lot :)
댓글 3개 더보기
댓글 달기
Your normal BUS speed is 3.0 using the bay slots. I've gone with the OWC PCI card to get 6.0 BUS speed.
https://eshop.macsales.com/item/Sonnet%2...
I pulled my RAID card after the battery went dead and I saw the cost to replace it.
It was about $135.00, here how it's done: https://manuals.info.apple.com/MANUALS/0...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
And can you remember what was the speed differences ? I mean some real numbers :)
댓글 달기
답변을 추가하세요
Rob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 267
