주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
Screen flicker/shaking after changing display
I replaced the display on an SP4 I have, and everything seemed fine. However, after now replacing the SSD drive I a running into an issue where after using the device for about an hour or so the screen starts "flickering", and shaking around.
I have read all about "flickergate" and the many suggestions on potential fixes with no change. (When the issue starts if I shut down and go into UEFI mode the issue remains).
Is it possible the fan is not starting up? Is there an easy way to tell without opening things up again?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Well, I dont know if there is anything wrong with the fan - but def. confirmed its a heat issue. While watching a movie yesterday the screen started doing that thing - I used an upside down can of compressed air on the back of the device and the picture returned to noral. For a little while
I guess I will take it apart and check the fan - just dont want to go through all of that again
댓글 달기
답변 1개
HI.
I had the problem of screen flicker when I replaced the screen on my tablet pro 4 with the spare part sold by ifixit. I finally had to opt for the Surface Pro 5 screen, which is compatible. You'll find my commentary on this subject here, which you might find useful:
https://fr.ifixit.com/R%C3%A9ponses/Affi...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Justin Greywolf 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 301
