주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
Random colors on screen
Hi there, my parents recently found their first iPhone and gave it to me, they said there were no issues, but when I charged it, the screen started showing random colors, I could tell it was responsive as the brightness was changing in the place where the slide to unlock text is. I’m able to hear sounds from the phone when clicking the emergency call button and tapping where the numbers would be. All help would be appreciated!
Update (09/25/2022)
Here is an image of the issue
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi
This issue is usually caused by a damaged screen or loose screen connector
You will most will most likely need to replace the screen but I would open it up first and try reseating the display connector by following this guide
iPhone 4 (GSM/AT&T) Screen Replacement
If reseating doesn’t work you will most likely need a display replacement which you can find liked below
https://www.replacebase.co.uk/iphone-4-r...
Hopefully this helps
Any questions please ask
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Hey there @HelloMacOS I tried reseating the connector, the screen started to show properly in the center, with some random colors around the edges of the screen, I then tried signing in and the screen started showing colors again, I even cleaned the connectors, it still didn't work. Thanks for your help!
@TechVid
Your most welcome
You will most likely need a new screen:-)
Oh ok, thanks again!
댓글 달기
답변을 추가하세요
TechVid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 140
