주요 콘텐츠로 건너뛰기
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163 질문 전체 보기
battery connection port on the motherboard?
Can someone please tell me the proper way to replace the battery connection port that is soldered onto the motherboard. I have a donor motherboard with a good port and I need to replace it on my AGS – 101.
Update (09/26/2022)
Here is the image
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi
I would remove it by applying low metal solder to the visible pins on the board then remove it using a hot air rework station to avoid melting the plastic on opposite side of the board to the connector
That’s the way I remove delicate connectors when I’m soldering
Hopefully this helps
Any questions please ask
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
My only issue is I don’t have a hot air rework station. I was going to try to heat up the mounting points with my small tip on my iron and try to pull it off that way but I don’t want to damage the board.
@biggriff
The hot air is the safest way but you could try this stuff called chip quick which melts at REALLY low temperatures
You could try it but you will have to be careful that you don’t melt/burn the connector:-)
댓글 달기
귀하의 답변을 추가하세요
Andrew2022 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 99
