주요 콘텐츠로 건너뛰기
A2116 / 2019 / 3.6GHz 쿼드 코어 i3, 3.0GHz 6코어 i5 또는 3.2GHz 6코어 i7 프로세서. 2019년 3월 19일 출시.
78 질문 전체 보기
Can I upgrade my 2019 21.5" iMac PCIe/NVMe to p5 Crucial SSD?
Hi, I have 2019 21.5" iMac 3.6GHz (19.2)
I want to upgrade the PCIe/NVM2 blade SSD to 2TB model using a Crucial p5 SSD Is this possible? Or use this Crucial p2 SSD
Also, can I add the memory capacity up to 64GB?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Here's a good source of info on your system 2019 21.5" Core i3 3.6GHz iMac (4K).
This model has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a "Fusion" Drive or an SSD at the initial time of system purchase, it also has a PCIe connector, but this connector is not present if the system only is configured with a hard drive.
So depending on your exact system it may not be populated with the custom Apple PCIe/NVMe blade SSD connection. Sadly you can't use the M2. SSD's made by Crucial as Apples is different. If present, here's the part info iMac Intel 21.5" (Mid 2017-2019, Select Models) Blade SSD Upgrade Bundle and here's the guide to put it in iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement while this is for the 2117 model its the same procedure and uses the same blade SSD drive. Otherwise you'll need to go with the iMac Intel 21.5" Retina 4K Display 2019 Hard Drive Replacement using a 2.5" SATA SSD.
Here's the needed RAM kit iMac Intel 21.5" EMC 3195 (2019, 4K Display) Memory Maxxer RAM Upgrade Kit to boost your system to 64GB (60-pin) DDR4 SO-DIMMs - PC4-19200 2400 MHz (for Core i3 system) or PC4-21300 2666 MHz (for Core i5/i7 systems) and here's the guide iMac Intel 21.5" Retina 4K Display 2019 RAM Replacement
iMac Intel 21.5" EMC 3195 (2019, 4K Display) Memory Maxxer RAM Upgrade Kit 이미지
상품
$369.99
iMac Intel 21.5" (Mid 2017-2019, Select Models) Blade SSD Upgrade Bundle 이미지
상품
$99.99
iMac Intel 21.5" Retina 4K Display (2017) Blade SSD 이미지
안내서
난이도:
운영
1 - 3 hours
iMac Intel 21.5" Retina 4K Display 2019 Hard Drive 이미지
안내서
난이도:
운영
30 minutes - 1 hour
iMac Intel 21.5" Retina 4K Display 2019 RAM 이미지
안내서
난이도:
운영
1 - 3 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
hozifa kanani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 27
전체 시간: 535
