주요 콘텐츠로 건너뛰기
Xbox Series S는 마이크로소프트의 최신 소형 폼 펙터의 디지털 전용 콘솔 게임기입니다. Xbox Series S는 Xbox series X와 함께 2020년 11월 10일에 출시하였습니다.
20 질문 전체 보기
Xbox Series S keeps shutting off
My Xbox series s keeps turning off at random moments. It can be after an hour of gaming, or literally 2 seconds after I turn it on. I’ve tried plugging it into different outlets, factory resetting, leaving it unplugged for an hour, still no luck. Not sure if I should buy another power cord, but it doesn’t look physically damaged. Not sure what I should do at this point. Please help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 6개:
Cheapest and easiest thing to do is a power cord. I would try that first.
Very good point
Thanks for the suggestion. I have one being delivered today. I'll provide an update as to whether the issue continues or not.
Good luck. Hope it works
Yea, the cord wasn’t the issue. The only thing I can think of before getting it repaired/getting another Xbox is trying a cooling fan? The Xbox doesn’t feel hot but maybe it’s overheating.
댓글 1개 더보기
댓글 달기
답변 2개
It could be a power cord issue, but it could also be the power supply that you need to replace. It could also be the motherboard, which I doubt. If you decide to get a new power supply, be careful with the broken one. Do not open the old power supply. Does your Xbox have good ventilation? Here's the article from xbox.com
https://support.xbox.com/en-US/help/hard...
이 답변이 도움이 되었나요?
점수 0
댓글 8개:
I came across something that I've only been able to test for one day, but I think it may have fixed my issue. My video display was set to automatic. Once I switched it to manual (HDMI), I was able to change my Xbox from 120Hz to 60Hz. Although the picture seems wide beyond the borders of my tv, I haven't had any more issues with the Xbox shutting off.
I'm not sure exactly how this fixed the issue, but it's been working ever since.
@gssiler7 That's good. well hope you find out how you fixed it.
It turns out that the issues still persist. I'm getting a diagnostics test run on it today. Just debating on if I'll pay a bunch of money for someone to fix it, or order parts and fix the issue myself.
Do you get a overheating message before it shuts off?
No. I’ve never gotten that message. I took it to ubreakifix and they’ll have some answers by Thursday. He said it could be the fan, power supply, or motherboard (if the motherboard, there’s nothing that they can do about it).
댓글 3개 더보기
댓글 달기
It just overhead nd the fan will turn on all way up
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gavante 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 60
전체 시간: 4,616
