Is there a tutorial for the logic board replacement?
Is there a guide out there on how to replace the logic board?
좋은 질문 입니까?
점수
0
좋은 질문 입니까?
iMac Intel 27" EMC 2429 Motherboard Replacement
This is the closest I can find. This guide is still in progress, so be careful.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 50
@civil35 this guide IMac Disassembly should work for you. To remove the logic board you do not have to follow all the steps just remove:
• Glass panel
• LCD panel
• Power supply
• AirPort card
• Backlight pressure wall
• Optical drive
• Optical fan
• IR board
• Memory
Note: The SSD-only CTO option has a hard drive power plug, on the back of the logic board. It shorts out the HDD power when no HDD is present. Transfer this plug (922-9877) if replacing the logic board.
This is a comment only since the snippet of the disassembly needs to be verified by you. Let us know if this worked for you .
oldturkey03 의
