주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
iPad Air 2 Spotlight Backlight Problem
Hi All,
I have been tasked to fix my aunt’s iPad Air 2 screen with some backlight issues. However, I don’t know whether this is a fault of the screen or the motherboard. I know bad backlight diodes/ICs will cause a problem similar to this, but the iPad is also bent on the side where the problem is occuring.
Can someone tell me whether this is a problem with the screen or motherboard so I can buy the right parts? Thank you in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
check for loose coils
댓글 달기
답변 1개
가장 유용한 답변
Was it ever dropped? That first picture that shows the gap on the side looks like a swollen battery. I'm not sure that will help the light issue, though. But if the battery is swollen, you need to replace it before continuing to use/charge it. Swollen batteries are fire hazards.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I second @amber's thoughts here; a swollen battery could be pressing against the screen and causing those problems. Definitely time to open it up. Follow the display replacement guide through step 28, then turn it on again and check to see if the problem persists. At that time, examine the battery for any swelling; it'll look more like a pillow than a flat rectangle if it's going bad.
iPad Air 2 Wi-Fi Display Assembly Replacement
Get back to us and let us know what you find.
댓글 달기
답변을 추가하세요
Ryan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 413
