주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
LCD Screen Replacement compatibility issues
Started with battery failure. (Swelled and lifted the screen) Replaced the battery, then it wouldn't power on. Worked it down to 3.3v missing. Replaced the motherboard as smd replacement issues not my "wheel-house". Now, video is jittery. I have also tried different display drivers, no change. Tried the video out to a monitor, no jitterproblem with the video there, but still jittery on the LCD screen. Saw another post that cited difference with 'Samsung' screens vs. 'L.G.' screens. Need some help on how to identify the right screen for my hardware. Secondary question. Is the video path different for the LCD screen, and the Monitor output jack? The jittery screen seems to appear after my Surface Pro 4 is on for a short time ~ about 5 minutes. I have also tried different display drivers, no change.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Unless you replaced the video board and cables in addition to the display, you shouldn't be able to connect the "wrong" display.
You can confirm which display you have installed by looking at the properties of the monitor in Device Manager. If the "Hardware ID" starts with "SDC3853", it is a Samsung display. (See attached image.)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David Laniewicz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 22
전체 시간: 191
