주요 콘텐츠로 건너뛰기
Repair guides and support for home heating, ventilation, and air conditioning system repair.
Furnace starts and runs but stops eventually
Trying to get my American Standard (Trane) Freedom 90 furnace on and running but having issues. When I turn it on it will go through the normal cycle and after 1 or 2 retries it does light (it is a gas furnace) and it will then stay lit and heat the house. However once it reaches the temperature set on the thermostat and it goes into a like down cycle it does not relight or ignite. I replaced the flame sensor, ignition, and control board, last year and its a new filter. What else can I do to get the furnace to stay lit?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
The furnace issue was resolved by cleaning out the condensate drain line which was clogged. Also, there was a couple dead mice in the combustion chamber area that may have prevented all of them lighting up and the flame sensor couldn't read seeing the last burner wasn't lighting.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have run into what appears to be a common problem with furnaces. My son the AC man couldn't figure it out, but I found it. Then he brought me another from a client. The control board in the unit has a Molex type connector on it. It does not get enough solder during mfg and eventually the solder cracks on the pins and connection is lost. Many times it is temporary until it isn't.
Disconnect power. Take a picture of the board and its connections. Remove the board. Carefully remove the conformal coating from around the connector pins and resolder all the pins with more solder. If you want to get a mag glass and try to see the cracked connection first, do it. It will be hard to see. Replace the board. If that is the problem, it will now run forever.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
In my case the control board wasn't the issue but you are right about checking that out and I didn't know about how to fix it. I replaced the board last year and I think my old board had the issue you are talking about. I had to buy a used one on ebay because my furnace is old and I couldn't find a new replacement part so I appreciate your answer cause I could end up having this issue and now I know what to look for. Thank you!
thanks for the comeback.
댓글 달기
답변을 추가하세요
Tony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 39
전체 시간: 190
