My Wifi is Greyed out, How could I fix it?
I have tried a reset and done everything WiFi works over Bluetooth using my iPhone but is very slow, It used to work just fine but now it doesnt it is a 16GB iPad Air 2.
좋은 질문 입니까?
좋은 질문 입니까?
This will not be an antenna issue. If the Wi-Fi is greyed out you defiantly have a board issue. You will need to check that the Wi-Fi chip is getting power, if it is you will need to re-ball or replace the chip. If it isn’t getting power you will need to find the faulty component that has failed. Microsoldering will be needed to fix this problem.
해당 답변은 도움이 되었습니까?
UPDATE: I just plugged it in and powered it on for the first time in a month, Wifi is back so I think it keeps getting overvolted or something like that.
It sounds like it could be an issue with the Wi-Fi Antenna. If you follow this guide to check the state of the antenna. I would attempt to reseat the antenna before attempting a replacement. Otherwise, it sounds like it could be an issue with the logic board.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 19
30일 전: 73
전체 시간: 1,049
댓글 1개
Why hello Xavier. Trying to fix your iPad lol The wifi antenna might be bad.
Connor Steffenhagen 의
