Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
좋은 질문 입니까?
좋은 질문 입니까?
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
해당 답변은 도움이 되었습니까?
Thanks
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 284
댓글 7개
Is this a necessary component?
Brad 의
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
Arnoud 의
do you mean on back of motherboard or on inside of rear case???
pollytintop 의
Inside of rear case behind battery....
Arnoud 의
Slide 30 in changing the rear case gives a good view.
Arnoud 의
댓글 2개 더보기
