주요 콘텐츠로 건너뛰기
Repair guides and support for phones manufactured by BLU Products. BLU stands for 'Bold Like Us.'
1766 질문 전체 보기
Why is my screen going black at night when I make a call
Why is my bluv81 screen going black when i make calls at night but during the day it doesn't behave that way. It doesn't light again even after the call ends. Am forced to hold the off and Volume down buttons simultaneously to restart the phone.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
You seem to be having some sort of interaction between your ambient light sensor and the proximity sensor.
The ambient light sensor tells the phone how bright the room is in order to adjust the screen brightness under different conditions. In a dark room it dims the display so you're not blinded, and in daylight it brightens the screen so you can see it against the light.
The proximity sensor is primarily used to detect when your face is next to the screen (as when you're making a phone call) or the phone is laid face down on a surface. In those cases it turns off the screen, assuming it's not being viewed under those circumstances.
Just to confirm, the display does go black when you make a call during the day and turns back on normally after the call is complete, is that right? As to why the proximity sensor is failing when you're in the dark but working in the daytime, I can't even guess. Does it go black when you dial the call, or when you put the phone next to your face?
If you cover the sensor with a finger, the screen should go dark and brighten back up when you remove your finger. Likewise, covering the ambient light sensor should dim the screen and holding the phone under a light should cause it to brighten. Sorry to say, I can't tell you where on the screen those sensor are, but they're normally near the top of the screen close to the front camera on most phones.
Unfortunately, information on the V81 model seems to be difficult to come by; I couldn't even locate a user manual for it, let alone repair guides or information on your sensors. Hopefully some of our repair techs on this site will have better luck.
There's always a chance a screen protector or a case is interfering with your sensors, so be sure to try removing both of those and seeing if the behavior changes.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
1. Press the Side Button to Turn on the Screen
The proximity sensor should automatically turn on the screen when you are on a call and want to use any call function. If the sensor fails to do so, you can press the side button and manually turn on the display to use call features.
2. Remove Rugged Cases
Well-known case manufacturers on Amazon and Walmart have precise cuts on their cases for your Android phones. When you use a case from a random unknown company, it might not fit your Android phone perfectly and mess up the side button functionality. It’s most apparent in rugged and hard cases. You should remove such covers from your Android phone and start making/receiving calls without issue.
Regards,
Will
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
augustuskalunda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 49
