주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2010 / 3.2 GHz Core i3 또는 2.8 & 3.6 GHz Core i5 또는 2.93 GHz Core i7, ID iMac11,3
382 질문 전체 보기
Vertical Red Line on LCD
I have a vertical thin red line running from the top of my Imac LCD screen to the bottom. It is about 4" from the left side of the monitor. It is thinner than a typical human hair. I ran the start-up boot disk and it did not disappear, so I believe it is hardware related. Any help on this matter is greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Thank you very much for your response.
댓글 달기
답변 1개
선택된 답변
It never pays off for me to answer these kinds of questions, in the answer box. 95%+ chance the problem is a capacitor or inductor filtering the signal or a transistor going out on the LCD controller board attached to the LCD. Most places that work on LCD TVs should be able to fix it for less than the price of replacing the LCD screen. The alternatives are live with it or replace the LCD screen.
해당 답변은 도움이 되었습니까?
점수 7
댓글 2개:
it paid today ;-)
dear sir, i have same problem, one fine red vertical line on imac screen in left side as discussed by ssgeraci. my imac is Mid 2011 ,A1311 with i5 processer, evrythin is fine and running well. past two years i am having this red vertical line on my imac screen, its juat stays there. i checked this imac connecting to another display through display port cable and vga adapter and in that display there is no red vertical line. it means the there is a problem in my imac lcd display. pls suggest about this issue. thank you
댓글 달기
귀하의 답변을 추가하세요
ssgeraci 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 4,373
